Somthing happend (Support requests)
by Bengt Larsson @, Thursday, May 16, 2013, 04:58 (4210 days ago)
System.InvalidOperationException: SplitterDistance måste vara mellan Panel1MinSize och Width - Panel2MinSize.
vid System.Windows.Forms.SplitContainer.set_SplitterDistance(Int32 value)
vid Icomancer.frmContentManager.splitImagesContainer_ClientSizeChanged(Object sender, EventArgs e) i H:\Icomancer\Icomancer\frmContentManager.vb:rad 80
vid System.Windows.Forms.Control.OnClientSizeChanged(EventArgs e)
vid System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
vid System.Windows.Forms.Control.UpdateBounds()
vid System.Windows.Forms.Control.WmWindowPosChanged(Message& m)
vid System.Windows.Forms.Control.WndProc(Message& m)
vid System.Windows.Forms.ScrollableControl.WndProc(Message& m)
vid System.Windows.Forms.SplitContainer.WndProc(Message& msg)
vid System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
vid System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
vid System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Please reset your settings:
by acaballero @, Thursday, May 16, 2013, 05:29 (4210 days ago) @ Bengt Larsson
Inside the icomancer's program group (in "All programs" menu) you'll find a special icomancer mode that will reset the User Interface to its defaults. Please try that.
For more reference: http://www.lavasoftworks.com/icomancer/doc/13_StartMenuEntries.htm
Somthing happend
by Theresa Orosz @, Lethbridge AB Canada, Thursday, May 16, 2013, 16:49 (4210 days ago) @ Bengt Larsson
System.ObjectDisposedException: Cannot access a disposed object.
Object name: 'frmSplashScreen'.
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Form.CreateHandle()
at System.Windows.Forms.Control.get_Handle()
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at Icomancer.frmSplashScreen.UpdateProgress(String msg, Int32 pbval) in H:\Icomancer\Icomancer\frmSplashScreen.vb:line 42
at Icomancer.clsProgressController.Update(String Message, Int32 Value) in H:\Icomancer\Icomancer\clsProgressController.vb:line 21
at Icomancer.modAppOps.AuthenticateApp() in H:\Icomancer\Icomancer\modAppOps.vb:line 130
at Icomancer.My.MyApplication.MyApplication_Startup(Object sender, StartupEventArgs e) in H:\Icomancer\Icomancer\ApplicationEvents.vb:line 105
I have tried to put this awsome program on my backup computer and this error came up. Do I have to register it separately on my backup computer.
thank you
Theresa Orosz
Somthing happend
by acaballero @, Thursday, May 16, 2013, 18:22 (4210 days ago) @ Theresa Orosz
Allright... as with many other users happens: something is messing icomancer at memory level. Something in your computer (mostly a high security software piece) is not letting icomancer even start, for this message comes from the splash window.
So please check with your antivirus software and/or run icomancer as administrator so it runs smoothly.
