First Time User having issues or bugs.. (Support requests)
by dana chrome @, Tuesday, May 28, 2013, 23:12 (4331 days ago)
An exception as rised when the source image was trying to be accesed:
Raised exception follows:
System.ArgumentException: The path is not of a legal form.
at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength)
at System.IO.Path.GetFullPathInternal(String path)
at System.IO.FileInfo..ctor(String fileName)
at Icomancer.frmCrafter.btnSaveAll_Click(Object sender, EventArgs e) in H:\Icomancer\Icomancer\frmCrafter.vb:line 1116
Please try to run icomancer as administrator
by acaballero @, Wednesday, May 29, 2013, 06:59 (4330 days ago) @ dana chrome
Even if you have UAC disabled, there are some times that even doesn't matter for Windows to mess up with unsigned apps (like icomancer). So run icomancer as administrator by right clicking on it and hitting "Running as administrator", then try again to craft & save and please let me know if that fixed up your issue.
If you're using XP, then please check your antivirus and tell it icomancer isn't a threat.
