Greetings from Italy, just registered (Tips & tricks)
by Stefano Regattin ⌂ @, Milan, Italy, Tuesday, July 16, 2013, 08:40 (4146 days ago)
Hi people there, here is Stefano Regattin Typing from Italy.
I have just registered your program from GAOTD several month ago and, after installing of free gradients template pack, I have received a program closure with this message:
System.InvalidOperationException: Il form ha fatto riferimento a se stesso durante la costruzione da un'istanza predefinita e si è verificata una ricorsione infinita. All'interno del costruttore del form fare riferimento al form utilizzando 'Me.'
in Icomancer.My.MyProject.MyForms.Create__Instance__[T](T Instance) in 17d14f5c-a337-4978-8281-53493378c1071.vb:riga 180
in Icomancer.frmLauncher.LaunchImbuingForm() in H:\Icomancer\Icomancer\frmLauncher.vb:riga 418
in Icomancer.frmLauncher.rtfLaunchImbue_Click(Object sender, EventArgs e) in H:\Icomancer\Icomancer\frmLauncher.vb:riga 358
in System.Windows.Forms.Control.OnClick(EventArgs e)
in System.Windows.Forms.TextBoxBase.OnMouseUp(MouseEventArgs mevent)
in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.TextBoxBase.WndProc(Message& m)
in System.Windows.Forms.RichTextBox.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Sure to have done the right thing for both us, I renew my Greetings from Italy, Bye.
by acaballero @, Wednesday, July 17, 2013, 19:30 (4145 days ago) @ Stefano Regattin
An infinte recursion? that sounds really weird. Please try the next thing:
1. Open my computer
2. Open the next location:
- If you have Windows XP: "C:\Documents and Settings\All Users\Program Data\LAVA SoftWorks\icomancer" (please note that "Program Data" may be in your OS language).
- If you have Vista/7/8: "%programdata%\LAVA SoftWorks\icomancer"
3. Delete the "collections_cache" and "Onscreen Settings.xml" files.
Try to start icomancer again and please let me know if this worked. If not, please reply with any error message you get.
