icomancer will not launch (Support requests)
by Don WHite @, Wednesday, August 28, 2013, 12:10 (4761 days ago)
I have a WIN7 (32-bit) system. When I click on the ico it says its loading and it shows up on the toolbar as being loaded; BUT, the GUI interface never shows on my desktop.
I've tried searching for it in REGEDIT (thinking it might be a display issue); but, I can't find it listed under LOCAL USER - SOFTWARE.
I've tried uninstalls and reinstalls -- still the same issue...
Can you assist, please?
Thank you
Don White
Do you have multiple montiors?
by acaballero @, Wednesday, August 28, 2013, 12:59 (4761 days ago) @ Don WHite
If you have multiple monitors, the problem should be caused by your layout. If not, then I don't have an idea of why you're not getting it to run.
Please try opening icomancer using the "Reset settings" shortcut. That'll clear any preferences -including the defaults- and put everything on zero.
Please let me know if the solution worked or not.
