An application unhandled exception has raised: (Support requests)
by Robert C. Pfaff @, Wednesday, August 28, 2013, 20:27 (4762 days ago)
When I start my computer and all of my startup programs start up I have just been seeing Icomancer's splash screen showing up and then I get 3 error windows with the exact message inside. I have copied and pasted its contents below and included a screenshot of it all.
System.InvalidOperationException: SplitterDistance must be between Panel1MinSize and Width - Panel2MinSize.
at System.Windows.Forms.SplitContainer.set_SplitterDistance(Int32 value)
at Icomancer.frmImbuer.frmImbuer_Load(Object sender, EventArgs e) in H:\Icomancer\Icomancer\frmImbuer.vb:line 57
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
Launch icomancer in "Reset settings" mode...
by acaballero @, Thursday, August 29, 2013, 01:34 (4761 days ago) @ Robert C. Pfaff
You'll find a shorctut for that mode in the Start Menu icomancer Group. That should fix that exception.
On the other hand... Please check not to have icomancer running at startup. It is not designed to run that way. It should not be a problem though, but it is completely useless to have it there.
