Failed to change color of folder using a textures folder (Bug reports)
System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\LAVA SoftWorks\icomancer\tracking_database' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
at System.IO.File.WriteAllText(String path, String contents)
at Icomancer.Vars.Databases.Save(String SourceXMLfile, XElement& TargetData) in H:\Icomancer\Icomancer\Vars.vb:line 429
at Icomancer.Functions.SetIconToFSobject(String IconFileName, String TargetFSobjectName, IconAssignationTypes AssignationType) in H:\Icomancer\Icomancer\Functions.vb:line 1766
at Icomancer.frmImbuer.btnApply_Click(Object sender, EventArgs e) in H:\Icomancer\Icomancer\frmImbuer.vb:line 217
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
