Image Magick updates (Support requests)
by DroidLuvr @, Sunday, August 19, 2012, 20:46 (5134 days ago)
Hi:
I keep getting a message from Secunia PSI that Image Magick is out of date and a slight security risk (the newest version is 6.7.9) but if I update, Icomancer doesn't work anymore.
Isn't there anyway to keep my programs up to date (security-wise) and still use IcoMancer?
Thanks!
I think you didn't install IM's proper version or didn't use proper settings...
by acaballero @, Monday, August 20, 2012, 09:56 (5134 days ago) @ DroidLuvr
I think you've downloaded and installed the 64-bit or static version... that's why it didn't work.
Now, if you want to update ImageMagick, you need first to uninstall the current version, then, download and install the 32-bit dynamic version:
http://www.imagemagick.org/download/binaries/ImageMagick-6.7.9-0-Q16-windows-dll.exe
When you get the setup wizard and reach the options page, be sure to enable the installation of the OLE Control (the last option of the list). You don't need any of the other options to run icomancer properly (they don't cause any conflict though).
If you follow that, you'll get icomancer running with no issues.
