On line Forms (General)
by David Wood @, Sunday, March 26, 2017, 06:16 (2927 days ago)
System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\LAVA SoftWorks\icomancer\collections_cache' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
at System.IO.File.WriteAllText(String path, String contents)
at Icomancer.Vars.ItemObjectCollections.SaveToCache() in H:\Icomancer\Icomancer\Vars.vb:line 295
at Icomancer.My.MyApplication.MyApplication_Shutdown(Object sender, EventArgs e) in H:\Icomancer\Icomancer\ApplicationEvents.vb:line 50
at Microsoft.VisualBasic.ApplicationServices.ShutdownEventHandler.Invoke(Object sender, EventArgs e)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnShutdown()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
Access to icomancer's program data is denied: UAC or your antivirus is guilty.
by acaballero @, Sunday, March 26, 2017, 12:35 (2927 days ago) @ David Wood
Please run icomancer as administrator or whitelist it on your antivirus so it is able to write to its data location.
