Icomancer will not work in Windows XP service pack 3 (Support requests)
by Wanda Clow @, Monday, March 27, 2017, 14:55 (2926 days ago)
System.Runtime.InteropServices.COMException (0x80041771): convert: 455: unable to load module `C:\Program Files\ImageMagick-6.9.8-Q8\modules\coders\IM_MOD_RL_PNG_.dll': The specified module could not be found. @ error/module.c/OpenModule/1302: convert: 420: no decode delegate for this image format `PNG' @ error/constitute.c/ReadImage/504: convert: 410: no images defined `C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\~lswim.9966395.im.515493.png' @ error/convert.c/ConvertImageCommand/3258: at ImageMagickObject.IMagickImage.Convert(Object[]& pArrayVar) at Icomancer.clsIconImageComposer.ColorizeLayerOnTempFile(String SourceLayerImageFile, String colorizeTo) in H:\Icomancer\Icomancer\clsIconImageComposer.vb:line 701
I installed ImageMagick 6.9.8 Q8 (32-bit). With the proper setting too.
Which Windows version are you using?
by acaballero @, Monday, March 27, 2017, 16:09 (2926 days ago) @ Wanda Clow
This post was intended for Windows XP users... It will help if you can say which Windows version you're using to look for further fixes.
by Wanda Clow, Monday, March 27, 2017, 16:12 (2926 days ago) @ acaballero
Windows XP Service Pack 3.
Please ignore my previous reply
by acaballero @, Monday, March 27, 2017, 16:12 (2926 days ago) @ Wanda Clow
I got confused and thought you were replying to an earlier post about XP.
I'm digging further in the topic, seems that ImageMagick is having dependency issues and icomancer is not the only package that relies on it being affected.
Please retry with this procedure
by acaballero @, Monday, March 27, 2017, 17:06 (2926 days ago) @ Wanda Clow
Hi again!
After digging a bit in ImageMagick forums, I found something that I missed and effectively fixes this other issue, so, please uninstall ImageMagick again (the new version I provided, 6.9.8) and reinstall it but adding the directory to the path:
I tested it and seems to work fine.
Please do this and let me know if it worked fine.
by Wanda Clow @, Monday, March 27, 2017, 17:40 (2926 days ago) @ acaballero
It works. Thank you very much.
Great!
by acaballero @, Monday, March 27, 2017, 17:52 (2926 days ago) @ Wanda Clow
Thank you for your patience and your help.
I'm prepping the next release so new users get it right from start.
