Problem with Synchronizing (Support requests)
by Maureen Potts, Tuesday, June 20, 2017, 18:17 (2842 days ago)
System.NullReferenceException: Object reference not set to an instance of an object.
at Icomancer.modSync.ItemUploadability(RemoteMaintenanceTypes MaintenanceType, String ItemGUID) in H:\Icomancer\Icomancer\modSync.vb:line 461
at Icomancer.modSync.Sync(SyncTypes SyncType, RemoteMaintenanceTypes MaintenanceType, String Category, PictureBox& ProgressIcon, Label& ProgressLabel, ProgressBar& ProgressBar) in H:\Icomancer\Icomancer\modSync.vb:line 96
at Icomancer.frmContentManager.btnLocaliconsSyncToServer_Click(Object sender, EventArgs e) in H:\Icomancer\Icomancer\frmContentManager.vb:line 2431
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
This happens when I load icons, sync to server. Under Manage/Synchronize tab
Windows 7 Home Premium. Program has administrator rights.
by acaballero @, Tuesday, June 20, 2017, 19:58 (2842 days ago) @ Maureen Potts
I'm doing the same and the remote tab doesn't refresh properly. I'm checking the server. I'll get back at you when I solve the issue and see if it is the same hitting you.
by acaballero @, Tuesday, June 20, 2017, 20:36 (2842 days ago) @ Maureen Potts
I couldn't reproduce the issue... though I discovered something weird: I can't sync up anything in folders, only elements on the root folder.
Are you trying to sync up from the root or from a folder?
PS: I'm running Win7 ultimate with admin rights, but no updates beyond SP1. Not sure if the error you're getting is being caused by some windows update or is a side effect of the issue I discovered... but I never got any exception.
Fixed error on the server
by acaballero @, Tuesday, June 20, 2017, 21:17 (2842 days ago) @ Maureen Potts
I'm 90% sure that the exception you got was triggered by the issue I've discovered... please try syncing again. If you still get the exception, just let me know :-)
by Maureen Potts, Tuesday, June 20, 2017, 21:55 (2842 days ago) @ acaballero
Still getting the error.
Mmmhhhh let me see...
by acaballero @, Tuesday, June 20, 2017, 22:29 (2842 days ago) @ Maureen Potts
It would be obvious, but... Are any of the icons in the root folder (My Crafted Icons) yours or you've downloaded them all?
If they're downloaded (created by other people) they should appear in orange.
I'm reviewing the logic and the case where all downloaded icons are not yours isn't being checked... so it seems there's where the exception is thrown.
Or where's the case? It would help me a bit more if you can show me a shot of your local icons and your remote icons...
by Maureen Potts, Tuesday, June 20, 2017, 23:10 (2842 days ago) @ acaballero
[image][image]
by Maureen Potts, Tuesday, June 20, 2017, 23:15 (2842 days ago) @ Maureen Potts
I sync the remote icons to the server. When I finished I also sync the local icons to the server. There was no error message this time.
No error message?
by acaballero @, Tuesday, June 20, 2017, 23:27 (2842 days ago) @ Maureen Potts
So for some reason the problem kinda fixed itself?
I'll try to reproduce the problem anyway... will get back at you tomorrow.
No error message?
by Maureen Potts, Thursday, June 22, 2017, 18:31 (2840 days ago) @ acaballero
Thank you
