An application unhandled exception has raised (Support requests)
System.UnauthorizedAccessException: Toegang tot het pad C:\ProgramData\LAVA SoftWorks\icomancer\tracking_database is geweigerd.
bij System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bij System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath)
bij System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
bij System.IO.StreamWriter.CreateFile(String path, Boolean append)
bij System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize)
bij System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding)
bij System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding)
bij System.IO.File.WriteAllText(String path, String contents)
bij Icomancer.Vars.Databases.Save(String SourceXMLfile, XElement& TargetData) in H:\Icomancer\Icomancer\Vars.vb:regel 429
bij Icomancer.Functions.SetIconToFSobject(String IconFileName, String TargetFSobjectName, IconAssignationTypes AssignationType) in H:\Icomancer\Icomancer\Functions.vb:regel 1763
bij Icomancer.frmImbuer.btnApply_Click(Object sender, EventArgs e) in H:\Icomancer\Icomancer\frmImbuer.vb:regel 217
bij System.Windows.Forms.Control.OnClick(EventArgs e)
bij System.Windows.Forms.Button.OnClick(EventArgs e)
bij System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
bij System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bij System.Windows.Forms.Control.WndProc(Message& m)
bij System.Windows.Forms.ButtonBase.WndProc(Message& m)
bij System.Windows.Forms.Button.WndProc(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
